No, you can just do a normal brake bleed: have a friend pump the brakes, crack open the bleeder and let some fluid out, close bleeder and release brakes. Top off reservoir as needed in between wheels.
If you have Brembos, you have two bleeders per caliper (inside then outside), and the guideline of starting at the furthest wheel doesn't hold; instead they say to start at the front right and work counter clockwise. Probably doesn't matter on a well-maintained car this new; doubt you have air in the lines so you're just purging the bit of fluid nearest the hot calipers.
Might as well check your brake pad life before you get start, since it's an easy job to combine if needed.
