itguy61
I forgot to post it here.. After replacing the o-rings both on the nipples and the bottom section of the can, I no longer have any vapor smells. I'm a happy camper now. I have plenty of extra of the smaller o-rings for the nipples if anyone needs some.
I am still having the smell after replacing the can. I can get down over that area and smell and it is coming up from the catch can. I did notice that when I took the nipples and the small O-rings off the old can and screwed them onto the new can I got metal to metal real quick. i only felt the o-start compressing a tiny bit and then abrupt metal to metal stop on screwing in the nipples. The bottom half of the can seems to be right now as I hit the squish of the O ring and then tightened down some beyond that.
Did you get thicker o-rings for the nipples? Where did you get them?
Everything else seems good, hoses clamps and O-ring on the bottom can between the an half.
