Catch Can too tight
Leo Slayer
Canberra, Australia
I bought a Mishmoto catch can last year and fitted it to my MY20.
I tried to unscrew the can on the weekend to empty it but it is done up too tight.
Any suggestions on how to empty the can?
Thanks
Leo
MY20 SWP
I hate when that happens.
I use rubber bands (several) and rubber gloves to try and get it loosened and learn from my mistake.
I then dont overtighten them and check them more often. Every 3,000 km - half the severe condition oil change interval..
Hope this helps.
Thanks
Leo
MY20 Snow White Pearl
Fully adjustable for opening difficult containers.
Hope this helps.
I'll try that this weekend, thanks
Thanks
Leo
I know the feeling had mine on about two months when i tried to release it. Had to summon my inner Arnie to get it done.
Petcock drain. You will not have to unscrew the catch can ever again. Mishimoto also sells a kit on the website.
When you do put the bowl back on, make sure the O-Ring has some oil or grease on it and it shouldn't stick again. No O-Ring should ever be installed dry ( it's just a matter of which kind of lube you use ).
Lube all the threads of the can, not just the o ring. Mine screws on and off like butter!
