Frank D Harders
- Mar 22, 2020
Best catch cans on the market?? First upgrade are they needed ??
Brand and same install. Somewhat mechanical but will need directions.yes they are absolutely needed. You'll be shocked at how much oil accumulates in them. I have one from amazon that is an exact copy of the mishimoto. it was $25. Does a great job.
Looking to do intake next. Any suggestionsyes they are absolutely needed. You'll be shocked at how much oil accumulates in them. I have one from amazon that is an exact copy of the mishimoto. it was $25. Does a great job.
PSA: the answer to the "needed" part of this question depends entirely on how you drive the car. Blow-by (the fluid being captured in a catch can) occurs more often at open throttle/high rpm/high pressure situations, and later in the car's life as the piston rings and cylinder walls wear. Driven casually a car produces very little blow-by [note: most DI engines produce some, even if it's a tiny bit this will add up over time]. Occasional heavy acceleration also might not be enough reason to install catch cans. On a long enough timeline all DI engines will need, at the very least, the backs of the valves cleaned or walnut blasted.First upgrade are they needed ??
Thanks. Currently 2020 GT AWD white ext red int. Love it already 20k. Daily mostly. Made my commute fun again. Yet to do anything to crazy speed/ drag. Waiting until BOv exhaust and jb4. Budget is low so it is sloe going. But learning the current limits as i go. Then suspension/ handling. Almost anyone can drive straight i likr cornersPSA: the answer to the "needed" part of this question depends entirely on how you drive the car. Blow-by (the fluid being captured in a catch can) occurs more often at open throttle/high rpm/high pressure situations, and later in the car's life as the piston rings and cylinder walls wear. Driven casually a car produces very little blow-by [note: most DI engines produce some, even if it's a tiny bit this will add up over time]. Occasional heavy acceleration also might not be enough reason to install catch cans. On a long enough timeline all DI engines will need, at the very least, the backs of the valves cleaned or walnut blasted.
That said - you can't do any harm installing them, as long as you're willing to maintain them and potentially argue with the dealership should the part ever come up in a warranty coverage discussion.
Being that you also want to know about CAIs, I'm thinking catch cans would be a good idea for your likely driving style/intent. I'm sure this applies to a lot of (most?) Stinger owners. But you can also just have the valves cleaned every 40 or 50,000 miles, which is going to be my strategy, and avoid ever drawing attention to mods directly connected to the engine.
Daily driving mine since new with about 3500 miles, I've only recently been poking at its limits. Can definitely handle well, with some backend kick if you push it too far or there's road imperfections (which I also recall reading in some of the car blogger reviews). In the handling department falls somewhere between a Buick and a Ferrari, depending on road surface, temps, tires, etc.Thanks. Currently 2020 GT AWD white ext red int. Love it already 20k. Daily mostly. Made my commute fun again. Yet to do anything to crazy speed/ drag. Waiting until BOv exhaust and jb4. Budget is low so it is sloe going. But learning the current limits as i go. Then suspension/ handling. Almost anyone can drive straight i likr corners
