3.3TT cat delete
chivasGT2
does anyone know where to find a sensor faker for the cat delete? i plan on purchasing Borla or Jun today but wanted to know if a faker existed? any suggestions?
Talking about secondary cat delete with the Jun BL pipes? if so Secondary cats are not monitored and need no additional sensor trickery. just bolt on and enjoy your new top end power. For primaries, you cannot delete primaries without experiencing turbine overspeed codes. You would need a flash tune from Tork Motorsports to address that.
thank you and did i waste my money purchasing the JB4 Tune
wast money and jb4 should never be in the same sentence
no disrespect i’m new to this and just don’t understand the processes
the gauges on the bluetooth don’t work i purchased the denso’s i’m doing the gas mixture the attached photos showing you the investment, now my question is what exhaust to purchase and since i don’t want catalytic converters so i need sensor fakers-i was told Tork Motersports Flash Tune - Would the york flashtune work with the JB4?
JB4 is one of the best first mods you can do. You have to run the OBD2 cable to have the gauges work in the app as the signals are derived from the OBD sensor PIDs.
However, if you are trying to run cat less, you are better to go with the Tork Flash tune, you will get similar or better initial results, and its the only way to avoid turbine overspeed CEL as he codes that out. You can still use the JB4 for Data Logging, methanol control, and fine tuning your car for additional boost and fueling. Stacking flash tune and JB4 is common in most other platforms, but on the stinger its kind of uncharted territory so be aware.
KLR Stinger I purchased the bluetooth-do i still need the OBD2 cable
Yes, the blue tooth connect kit only sends data from the JB4 to your phone. The obd2 cable is required for the JB4 to get the data from the car.
i am so glad this place exists
Welcome to the club, lol!
