The strut bars don't produce heat they get hot because the engine bay is hot. Carbon bars aren't going to fix the issue.Looking to reduce underhood temps for my Injen CAI and since the Aluminum Strut tower braces get hot at higher temp, is there a legit carbon fiber replacement that would lower temp?
Well they won’t retain or radiate heat is my thought “... like an iron in the fire...The strut bars don't produce heat they get hot because the engine bay is hot. Carbon bars aren't going to fix the issue.
nope, it's minimalWell they won’t retain or radiate heat is my thought “... like an iron in the fire...
It's not going to have a noticeable effect. Aluminum dissipates heat fairly fast. Like I said the only reason it's getting hot is it's that hot under the hood during operation. This is why you should use intakes with dividers and not just straight up open elements.Well they won’t retain or radiate heat is my thought “... like an iron in the fire...
