Lynix
Seems like I’m getting MAP code errors and possibly some sensor is messed up? I’ve check all the connections that the JB4 uses and I don’t know what’s messed upedit: I see you bought a used one....that adds another layer of questions...
- Did you separate the coil packs?
- Did you remove the intake manifold to to the plugs?
- Did you torque the spark plugs properly?
- What did you gap the plugs at?
- Did you ensure that the connections are plugged in correctly?
- Did you open the JB4 enclosure? If so, any pinched wires/chipsets or did you get it closed back up nicely?
