Car feels slower
Connections all tight? You have no boost.
Car isn’t pulling at all. I took some logs on map 2
This SAME thing happened to me on Saturday. I normally run map 2 & pull 16-18psi on full throttle (warm days). I had to pull over, I turned the car off then back on, switched from map 2 to map 1 & then back to map 2 & it started working again for me. Had it installed for a several months. Had a minor boost leak that I fixed so immediately thought it was that again but nope....
It literally felt like I was in valet mode despite JB4 showing everything was fine, no codes, & map 2.
Have you tried switching maps?
I’ve tried all of that and the car seems to not be getting any boost. Even stock map the car isn’t pulling. Turned the car on and the check engine light was one, the code was P0107. I just got the car back from the shop friday for some minor front end repair. I’m thinking when they were repairing front something happened. The car was fine before it went into the shop and not a day later this happens
Checked the wiring everything is on tight, like i mentioned even with the jb4 disconnected from the car the car doesn’t pull.
