Having done the sway bars this past weekend, I would say that this tool looks like a definite maybe. A few things to worry about here are the height of the space and the depth at which your working. I was using an 18" flex head ratchet with a deep 14 mm socket. The flex head feature wasn't necessary, but the length was. Once the socket was on the nut the ratchet came out past the wheel well just far enough for the handle and a couple inches of shaft. In the Amazon pics, this thing looks kind of beefy so have a plan on how to get a 1/4" adapter onto the end plus a 14 mm socket and still have clearance to maneuver to get on top of the nut. I'm guessing you'll also want something to increase the length of this as well.I have a set of sway bars and am trying prepare as much as possible for that ONE NUT on the driver side. Can anyone that has done the deed comment on the possibility of using the tool below to get a 14mm socket on the nut while the rear suspension is in full droop?:
Thanks,
George
Good guesstimate. Below are the torques spec'd out for suspension components in the service manual:at least 40+ lb-ft by my hand's estimate
Cursing is encouraged in such situations; it shows the car you mean business. I would do the rear bar first as well, because doing the front is so easy that it will be a lovely way to wrap up the job after fighting that rear driver's side nut. For comparison, I used all the supplied lube on the bushings.
Thanks everyone,
I picked one of those tools up since I can use it for other jobs. I like Huckster's idea of removing the fender liner, cutting the zip tie and moving the lines a little if it doesn't work. Being in a hot garage loosening and tightening that ONE NUT one click at a time will be very depressing.
George
Any reason you went ARK over Eibach?Thanks Snowwhite. Also thanks again for pointing me in the right direction for the ARK bars.
I'm guessing the thicker (+2 mm front and +1 mm rear) bars plus the solid vs tubular in the front is better for the added weight of the AWD.
Nice. Have to love a matching set.Mine‘s RWD, but I already had the ARK GT-F springs, so I wanted a matched set. The swaybars are significantly heavier and thicker than the stock units. The front one is massive. The mounting bracket design looked easier to deal with in that damn rear bolt, as well. The increased diameter over the eibachs sealed the decision.
absolutely the best mod I’ve done to date. Those weird suspension movements when the car didn’t seem to know which way to bounce at times are gone. It feels like the structure itself is stiffer, without making the ride any harsher than stock, at least on the roads down here in FL.
Give it a try. I'd
