Can someone check the log thanks !!
Running 91 gas , just air intake with spark plugs
It’s like you’re running 87.
Top tier gas? Finish that gas and refill with top tier 91. You can reset the ecu and log again. If the log is ugly again, fill with E85 mix if you have access.
91 is the highest we got in Colorado , got e85 available what blend should I go with ?
I'd start with 3 gallon of E85 when you fill up with 91. Reset ECU by unhooking battery for ten minutes or so, then drive a few miles to learn, then log.
