built transmission on a kia stinger gt2 awd 2018
azell8k
looking for someone that could build a transmission on a kia stinger gt2 has all kinds of aftermarket parts upgraded turbos need atleast 800 to 1000
also has a motec ecu
Welcome. I moved this topic out of the community lounge and into the main Stinger forum. Where are you located? It may make more sense to move this topic into one of our regional sections...
ok thanks florida
Level 10 in Northern NJ has done one and IPT in Patterson is another great builder.
do you happen to have phone number
Lots of guys from the Toyota community have complained about customer service from these guys, but they’re very good at what they do.
I only hear great things about these guys.
Both are well known nationally.
In both cases, you can simply send in your valve body, or go full build and send the whole trans. They will make it bullet proof in the later case, but it will cost you thousands.
If you search the forum, a member did a write up of his experience with Level 10.
