They added spacers and there’s a few millimeters between the calipers and wheels now. Few millimeters is enough, right? The rear wheels have plenty of clearance.I'd probably just run a 5mm spacer all around if that will give you enough clearance. Like mentioned i would clean up the calipers and use some high heat red paint to touch up the areas with paint shaved off or they will get nasty looking pretty quickly.
Think I should complain about the scraped calipers on the front?.. and ask when they plan to take care of the damage to the calipers..
Thanks for the note guys. I should have known better than trusting town fair tires. I paid close to $1600 for wheels and tires.
