hello new to the forum have 2018 stinger gt1 have not driven the car in about 9 months meth tank had been ran dry tried purging it using jb4 purge function did not work supplied 12 volts to pump to get meth up to solenoid adjusted map to map 8 took it out for a drive anything over about 10 psi of boost car started to break up almost like an ignition type misfire no codes at this time changed map back to map 2 same results on test drive switched to map zero same issue pulled 2 spark plugs look good no fowling was going to unhook battery to night let everything reset just updated jb4 firmware was looking for any help with the issue car is almost undrivable i will make a couple pulls tonight on different maps and post logs
mods: cai ,big mouth intakes ,larger front mount, down pipes full exhaust, hks blow off valves, jb4 with meth injection ,denso 5346,accel pedal module
