Siddhu290
Not sure if this was discussed earlier. When I brake, the chassis moves forward and back after coming to a stop- more like rocking forward and back. Is this normal?
This happens even when I brake very gently. It just rocks back and forth like a jelly.Try braking less aggressively.
Take your car in to service and get that checked out.This happens even when I brake very gently. It just rocks back and forth like a jelly.
No issues with mine. I often like to downshift and Stinger nearly comes to a stop by it's self. If no downshifting i brake normally (gently) and don't have any issues.This happens even when I brake very gently. It just rocks back and forth like a jelly.
I have noticed this no longer occurs on my Optima after adding lowering springs and I keep saying to my friends how much more stable my Optima Hybrid feels compared to the Stinger. I was planning on getting lowering springs in hopes of eliminating this, but if the issue is the electronic shock, I'm thinking the issue might still be there. Would love to hear from folks that are on lowering springs, with the ECS system, if this issue still occurs. Truthfully, I just want to do the sway bars and not have to lower the car as it is low enough as is already.
Bingo. I watched all your video examples and cannot see any significant differences. At near 16K miles, I haven't noticed anything amiss in how the car comes to a stop, either briskly or pulling forward "an inch at a time", as it were. Of course, I have also never driven an Audi, BMW or any other performance oriented vehicle. This is my first. I am definitely classed with "most drivers."This sort of thing just tends to go totally unnoticed by most drivers.
That’s the thing... your ability to detect this is almost entirely dependent on what you are used to.
And once you know it, you will see it in regular braking too (though, perhaps to a lesser degree).
Let me know if you don’t see/feel it... It’s been there in my every GT2 test drive, as well as my purchased GT2.
Once again, if your previous car had lots of nose dive and didn’t stop flat, you may have a hard time detecting this. But I assure you, it’s there with the Electronic suspension.
I am also surprised you couldn’t see the difference in the videos posted. Once you *feel* the sensation, you’ll easily be able to *see* it too in the videos.
This is normal for this car. I have been meaning to make a post about this (and a few other things I hope Kia addresses for the next generation of Stinger).
I bet your Stinger has the adaptive shocks. Right?
Because the regular shocks don’t seem to do this.
In most cars, when you brake, the nose dips down and rises back up after the stop. Our Stingers with Adaptive Shocks turn the rebound damping up relatively high at low speeds and when braking.
This increased shock stiffness keeps the back of the car from raising up as much during braking and also resists the release of the dive motion in front after the car stops. The effect is relatively flat braking. But those forces resisted by the stiff shock setting at low speeds don’t go away. So even though the shock/spring isn’t diving, now the force is compressing the bushings in the upper strut mounts.
The bouncing you feel front to rear when you stop is the cars weight loading and unloading those upper suspension mounts. Since the motion is occurring on top of the shock/spring, instead of within it, the shocks can’t dampen the motion. Hence you can feel it rocking back and forth on the mounts until the energy of the stop has dissipated.
All of the ECS Adaptive Suspension behave this way. It is especially noticeable stopping in your garage, driveway, parking spot, or any time that you inch forward and brake to a stop. It also exists from stops at higher speeds too.
A lot of people will say their car doesn’t do it, but only because they don’t notice it. Most people aren’t in tune with these kinds of motions and they go unnoticed. But, if you go look for it, it’s definitely there. Additionally, once you notice it, you will always notice it.
Frankly, this motion feels cheap, unrefined, and detracts from the overall refinement of the vehicle around town (or anywhere stop and going are frequent). Highway drivers are less likely to notice this, because they stop and go less. But in the city, in the neighborhood, and or parking it is definitely a nuisance. I surmise Kia felt that most people wouldn’t find it objectionable...
But a car of this nature should come to a complete stop in one smooth motion. It does not.
Right now, the only fix is to soft (limo) stop. That is, brake normally, then in the last few mm of the stop ease off the brake just a bit. By doing this you will reduce the rocking tendency.
On second thought, coilovers with pillow ball top mounts would eliminate this too (but then the car might rock on the tires, rather than the strut mount). Tire, Spring, Strut, and bushing stiffness all have to be an in agreeance with one another to avoid this. They form a system. If Kia chose to do so, the ECS could easily be designed to minimize this rocking, with no detriment to any other area might I add.
Give me a moment and I’ll post up some vids to show everybody what you are talking about, because it’s one of those things most people have probably never noticed.
