2020 GT Indigo———I installed a brake snip switch to be able to launch with more boost. Now when the switch is off, the auto off light flashes and car goes into limp mode. I have tried disconnecting battery to reset everything but every time I try to use it, it does the same thing. Please help. Thanks!
Double-check you sniped the correct wire... There are two with similar color...
Now, with switch off/wire has continuity once more - it should operate just fine... So, I too, am puzzled with this one...
With switch on - does brake snip/full launch work?
Just take out the Stop Lamp fuse and replace it with a Fuse tap, inline fuse holder and a switch.
Put in Drive, turn off switch (simulates fuse pull) and now you can brake boost. After you are done switch back on, turn Car on/off to clear dash lights and back to normal.
