Brake Caliper Fitment Guide
dnprall
Does anyone have a PDF of a brake caliper fitment guide for the factory brembo brakes?
Just by eye balling the fronts, there looks to be very little clearance with the stock 18 inch wheels. The wheel manufacturer doesn't have Stinger info so if I can find a fitment template, that'd help a lot (I also sent out feelers to Kia and Brembo).
Thanks.
Are you trying to install OEM 18s and wondering if they'll fit? Some stingers in the midwest/north came with the 18s at standard with All Season tires.
My GT2 has the 18s with all season tires. Of course those wheels fit the Brembo calipers. Just with eyeballing the front calibers, there doesn't appear to be much clearance at all (seems like just a few millimeters) so I'd really like to find a template to help with fitment before ordering wheels. The wheels I'm interested in have an offset of +35 mm (18 x 8.5) (so essentially the same offset but the wheel is wider than stock by 0.5 inches) but the wheel manufacturer doesn't have Stinger data to confirm clearance or not.
What brand? I got Enkei TY-S, 18x8.5 ET35 in the front, and they fit just fine.
Konig Ampliform same size as yours.
It does depend a bit on the barrel shape, AFAIK. I looked at the Konigs, but IIRC, I think they didn't have a good fitment for a wider rear. And/or couldn't get confirmation from a dealer. The Enkei's were about the same price last year.. $225-250 per wheel. Also flow-formed.
