No, level drivewayAre you parked on an incline when it happens?
about 50% of the time, when I put the car into reverse, I get a loud clunk and noticeable vibration. Anybody else have this occurrence?
For any car by far the best method is to hold brakes, place transmission into neutral, engage park brake, lift foot off brake and then finally engage P
This is to ensure the brakes hold the car and not the park pawl which also means shifting out of park will be silky smooth.
yeap, i had the same problem.I used to have this happen when going into Park every now and then. I later figured out it had to do with brake pressure (for some reason). If I'm firm on the brake pedal when shifting, it hasn't slammed into Park for well over a year, now.
