BlackGhost
I had to learn the hard way ... but if you buy second-hand wheel(s), ask for their factory wheel nuts also.
See pic below. The one on the left is the type that my 2017 Stinger GT came with. The one on the right is the new version, which has a captive washer and the dome-section at the base is quite different. Even though the wheels look identical (i.e. the original GT version worldwide), the holes for the threads in the wheels are slightly different. Someone on this forum may be able to advise exactly when this change occurred, but I think it is with Stingers being sold from early 2020.
I won't go into huge detail here, but let's just say over a period of ~6 months, the 'old' wheel nuts on a 'new' wheel actually worked their way loose, and if I hadn't diagnosed the problem (clunking sound from the rear while driving gently and decelerating), I might have had a wheel coming right off. True story.
Bit short-sighted of KIA to do this. They should have associated a distinct change in wheel design to coincide with a significant wheel nut design change.
KIA P/N for the new version is 52950 37000
