The other car in the garage is a Pontiac G8GT. If I accidentally leave the key in the ignition but the ignition is off, over an evening and night time it will take a large AGM battery all the way down. I have a nice charger that will take it back to a full charge.
If you were to leave the Stinger key fob in the car, again with no stereo, or whatever does that run the battery down?
The Pontiac also has a 10 min timer. If you leave lights of anykind when on when you exit the car and the ignition is off, the car turns the lights off. Does the Stinger have that? If so, I haven't found anything that suggests it does. Thanks, Don
