Does anyone know the default torque split on AWD models in Normal mode? I believe in Sport mode the default is 80/20 keeping it a RWD bias. Does the torque spilt vary for each mode?
I believe they come with 19s.18 is an option.On the GT, do AWD models only come with 18 in wheels? I thought all GTs come with 19's and 18 in is an option.
in the US , and they come with a non staggered set up with AS tires . a few of us up here have swapped out the stock rubber for UHPAS tires on the factory wheels.This is correct.
Its max 50/50 .Curious as well.. Anyone know the maximum output of power it can send to the front wheels? Can it do 50/50 split or is 60/40 the highest?
Its max 50/50 .
would you mind telling what UHPAS you changed toin the US , and they come with a non staggered set up with AS tires . a few of us up here have swapped out the stock rubber for UHPAS tires on the factory wheels.
