AVANT GARDE, ART SERIES FLOW FORM PROCESS, for your STINGER from Get Your Wheels.
GetYourWheels
Authorized Vendor
Santa Fe Springs, CA
ENGINEERING
M610
Our newest Advanced Rim Technology (A.R.T.) is the latest manufacturing process that incorporates traditional monoblock wheel casting methods with spin forming technology to drastically improve the material properties and enhances the overall strength of our wheels.
The A.R.T. process impacts the micro-structure of aluminum by utilizing three hydraulic rollers to apply pressure to form the inner rim area after the wheel has been casted. The rollers move down the barrel, applying pressures to stretch, compress, and form the entire wheel barrel, ultimately increasing the tensile strength and elongation properties.
The end product is a lighter, stronger wheel that has an increased load capacity and shock resistance over the traditional cast aluminum wheel. A.R.T. provides up to a 25% weight reduction compared to a traditional cast wheel. The M610 weights for 19″ sizes start at 21 lbs per wheel while the weights for 20″ sizes start at 22 lbs per wheel.
An initial casting unique to Flow Forging Technology is placed onto a steel rim and mold and prepped to be processed.
STEP 1​
Extensive heat and pressure is applied using three individual rollers to shape the aluminum to the rim mold. The individually shaped rollers fortifies the barrel to the specified width and density allowing for a stronger wheel using less material.
STEP 2​
The molecular compound of the aluminum significantly hardens in a streamline direction resulting in a wheel with a higher impact tolerance and considerably lighter in weight.
STEP 3​
1614799495434.png1614799510765.png1614799521731.png1614799535031.png1614799547464.png1614799560815.png
SIZES AVAILABLE in 19-21, depending on the model.
Custom finish available.
Wheel and Tire package available with Free Shipping.
Any questions, let me know.
Thank you,
louie@getyourwheels.com
M610 19X8.5 19X9.5 available or bespoke fitment and finish.
Contact me for your set and ask for me for Forum Pricing!
Thank you,
(562)249-7184
M621 IN Bronze Burst. What do you guys think of this white on bronze combo.
Contact me for your ART series flow forged wheels.
Wheels and Tires package available upon request.
TPMS and Lug nuts for Turn Key installation.
Free shipping!!!
(562)249-7184
