Assistance Needed with BMS Pedal Tuner
soldierfrommo
I installed the BMS pedal tuner on my Kia stinger. Simple install. Started the car and the vehicle diagnostics brought up a message saying there is an issue with my Engine Control System and now I also have the check engine light. Any ideas on how to fix this without going to the dealer?
Usually means you didn't calibrate the unit properly. Look at the install guide and calibration video?
The pedal tuner only came in a box without any instructions inside or on the box. Where can I find the video or instructions?
I didnt calibrate mine correct the first time either. After getting it correct, I thought it was a great product.
Same issue here. Something as important as that should be on the box at least.
Yeah I was disappointed with the packaging and instructions (lack of) with the BMS pedal tuner, but install and calibration was pretty easy. I have a Racechip and wanted to get the BMS JB4 but I don't want to spend an afternoon researching installation instructions on forums.
The 2L photos should be in the same guide as the 3.3L, if missing we'll have to get those added. Everything is basically the same including the sensors but the sensors location is shifted over a foot or so.
This goes without saying but if anyone needs technical support or information on installing or setting up a BMS product do not search forums or the internet. Email our technical support for assistance, support@burgertuning.com.
can I recalibrate my bms pedal tuner again
Yes as often as you want but it's a waste of time unless you changed your gas pedal or moved it to another vehicle. :)
