App only shows boost?
lovelacer
My app only shows and logs boost and maps.
I've followed all troubleshooting steps; reseated all Bluetooth adapter and car connections twice. I've updated firmware to version 6 via the app. I've killed and restarted the app many times.
Is there a stinger specific trick to get all the gauges working? Does it matter which side of the map and tmap plugs the brown and rainbow wires are on? I definitely feel that the JB4 is working and is awesome.
Do you have the OBDII connection installed?
JB4 works without it, to a more limited extent. You need the OBDII cable (OBDII connector on one end for under your steering column, a small 4 pin connector for the JB4 on the other end - it was in the box with the JB4) connected for all the logging and full tuning features.
I had the same issue, they thought the obd cable was defected and sent me a new one. The new one was the incorrect one so the sent me another, tried it and it seemed to work. I took the JB4 off though within a few days afterwards.
I would try to get an a new obd cable and see if that fixes your issue.
Normally CANbus data missing is OBDII related. Unplug and replug it in to ensure it's in there solid, same goes for JB4 side, just to be sure.
Had a chance to work onoit again today. Unplugged and moved OBDII cable around and sure enough started working. I had previously done this as well and it didn't work but this time I moved the cable a bit where I threaded it through the grommet and that seemed to be the thing. Works great now. Thanks for the help!
Did you actually go through the grommet or around the grommet? If you went around it odds are you are pinching the cable and can cause damage to the OBDIII cable. I would recommend either puncturing the grommet and feeding it through or at very least load up on the Electrical tape where it pinches around the grommet.
Will the rpm gauge work without plugging into the ob2? I just have the Bluetooth connection set up.
