3.3TT Anyone up for a log review?
NoKia
I've installed the jb4, deso plugs, catch can and intakes. I use map2 as my daily drive, it's not too often I hammer it but when I have open road or a clear onramp I like to give myself a bit of whiplash. I just wanted to toss up a few logs to make sure they look ok, that there's nothing concerning because I often have boost / pull fluctuations meaning sometimes it's like 'weee' and other times it's like 'holy sh*t hang on*. On the same drive I can have a a few WOT hits that feels nice, then another that really hits. It's quite noticeable. I know it's not always going to be consistent and there are factors that will impact it like temps, altitude etc, but again I can do a few rolling pulls that are good then one that's great even after I should be heat soaked. Other than that I'm super happy it's been running great!
I should add I run nothing but 94 octane, have the fuel wires installed and it's the bluetooth module.
Thanks guys!
Looks good but not the best of pulls. Start in 3rd and go WOT thru 3rd into 4th. You’ll get going pretty fast so make sure you’re in a safe place.
Thanks for checking them out - what shows you that they are not the best of pulls (I agree they didn't feel great, I think I launched controlled one which is just plain bad, even starting out the throttle response is terrible and not only does it lag but the car seems to be waking up from sleep for fraction of a second once it gets going before it boogies)? I think one was a 0-60 and the other was a 0-60 and a few more WOT after that. I could toss a few 3rd/4ths up as well, just trying to make sure 1. The afr etc look safe and nothing is going to pop and 2. that they are appropriate and in line with most other people that are running map2 given the mods.
You need good solid pulls to evaluate whats going on. Driving around with the odd step on the gas logs are useless. What part of the country are you from?
Southern Ontario. Air is cool, 150m above sea level. Was it the boost that didn't look good and what methodology would you suggest to getting the good solid pulls to diagnose? Like do several in a row, same day / different days, different temps, different gears, in manual mode vs down shifting in auto?
Here are a few more 0-60 runs, a few mid gears and I also tried map3 for the first time after having this installed for a month or so.
I've felt really good pulls at times when this was initially installed, and while it shows boost is higher than stock in real time it feels sluggish...don't get me wrong it's still quick it just feels like it's holding back / being held back. It's rare now that I'm getting good pulls like what I felt before. Not sure how accurate the 0-60 is and I know that it can vary widely depending on your launch, heat, etc but it's not coming near what it used to under the same conditions - ex same weather, temp, elevation, track strip, taking the first few runs, using launch control should be producing similar results that shouldn't vary too much, not by several 10ths of a second anyways.
Thoughts?
Start in 3rd gear at about 60kph/40mph go WOT til about 145kph/90mph. Cheers
Here are a few more, boost doesn't seem as high as it once / doesn't hold and the pull doesn't feel the same but maybe my butt dyno is off. 1158 has several pulls from 60-145 or so and a few wot at higher speeds, then a few misc ones through different ranges in 2222
Looks good, corrections are minimal at best. You got a little more boost in the second run and it still looked great. Map3
Thanks for looking them over. I was for sure getting more boost before, at stock around 12, map2 in the beginning I was getting 17-18 solid. I tried 3 before and didn't notice much of a difference but it was because I was a little nervous to give it a shot. I'll try again and post some results!
