Ambient Lighting Control Disappeared From Display
ldusseau
I just discovered tonight that the ambient lighting control (color selection) disappeared from the display on my 2018 stinger. There are only two controls, Ambient light brightness and color are missing. I did a reset of the display and they are still gone. Ambient lighting isn't working either. Anyone else run into this?
I finally found a thread on this last night. There were posts that said replacing a fuse in the box near the steering should work, but one poster said you "...need to turn the fuse box off". I've never heard of this, can someone please explain? TY.
If you remove the fuse panel cover inside the car you'll see an on/off switch. Switch it to off and give some time before you switch it back on.
Thank you! Never knew that was a "thing".
Thank you to everyone who helped out. I was detailing the interior yesterday and decided to look into the issue. I shut off the fuse box, found the correct fuse, pulled it out (not blown) popped it back in and viola! Ambient lighting controls are working!
