Adding a subwoofer
BIGBREW
I want to add a self contained subwoofer, just to spice it up a little. I'm not trying to take up too much room in the trunk.
I'm going to use the high pass input on the amp. Where can I tap speaker wires and a key on hot wire without too much aggravation?
Thanks in advance
Factory amp right rear trunk panel I thought I had a picture of the schematic but I deleted it sorry but there is a lot of information on here if you search for it
i put in a Kicker powered sub that i had in my last 2 cars ... easy install.
has high level inputs and auto-sense turn on options, so no line output converter or remote turn on wire needed - tap speaker wires at amp, power and ground, and ran optional bass level remote.
easy to remove if extra trunk space needed - just disco the connector to it and take it out.
