Snicklefritz
Sustaining Member +
- Nov 28, 2022
That's how my issue started, or rather after I changed all the plugs on recommendation, then two weeks later I started to notice hesitation under boost, for the first second or so, then it would smooth out. after another 4,000 miles or so it was worse and the cel started to show and stay on longer. that was when we found out the plug was cracked. after the replacement plug also went bad that was when we discovered the bad coil pack / boot.It was a single cracked spark plug. They said the coil pack was okay....see if it lasts
