voon
- Nov 29, 2017
First: I like the stinger, still. It's a comfy car to do your kilometers in, it has the gadgetery I need to keep my nerd needs fulfilled etc. My rear hatch door does not rattle or do other weird things. All in all, great car so far. not going into the positives here, wrote enough on that
But I do have a few (sometimes personal or cosmetic) remarks on the Stinger. Many are not surprises, I knew them when I bought the car ... it's just things to consider.
- Something is with the leather. It's lovely comfy and soft and seems to be decent .. but dent it once with a sharper edge and it seems to stay that way. Like the rear middle armrest, hitting the belt locks. Otherwise I like the leather.
- Seat cooling seems a bit irregular. Sometimes I get proper air, sometimes it seems not to really work ... I wonder if I sometimes block a tunnel below by just sitting and sometimes not? Or maybe I'm seeing things. But I do mean wearin the same pants etc.
- One of my seat cool/heat switches went bad real fast. No proper click anymore, just spongy. Had it replaced, not iwt's fine. I hope that was a random unlucky thing.
- I wish I could not have the sunroof in Switzerland. I thickens the roof like all sunroofs and that's a bugger with my 6.3" height .. I'm reeeeeal close to the roof. it's not that it is bad, I just don't need it really.
- The rear windows not closing/opening on a single touch is .. pff .. was that necessary? not that I need it often, but still.
- The trunks floor is a lose, cheap looking affair. The flimsy cover is just supported by the styofoam below, which makes dangerous sounds when I sit into the trunk to work on something. Make this fit better and put some decent plastic supports below etc.
- Where is the 12V connector in the trunk? I had to retrofit one, which now conveniently and invisibly is next to the lights on the right side.
- I have to figure out the unlocking mechanisms .. sometimes, I walk to the car, the mirrors swing out and I can just open it .. sometimes I need to press the button. Did I forget to lock it last time? I'm confused.
- I want no distance control in my tempomat. It annoys me to have to hold the distance button for a few seconds every time. I want this as an option in a menu.
- Same goes for start/stop. Annoying to have to disable it everytime.
- I could live with just two beeps on the automatic trunk opening
- I'd prefer a flat level trunk exit. Why do cars raise it? Stability? Design?
- The round air exit deisng looks nice .. but I can't toally get rid of cold air going my way witht he round middle ones .. the air reflects off the walls they're sunk into when you direct the opening away from you. Mild annoyance.
- No telephony button on the center console .. wat? Used my star button for it .. so .. mild problem.
- Frontarmrest a bit "thin" .. starts to creak scarily/cheaply when you apply some weight
- Armrest compartment should be aircooled .. just needs a hole from the tube below going backward anyway. Also: A USB port inside the compartment can be cool for some stuff.
That's it so far. Let's say it again: I love the car so far and would buy it again
