G70LEbyAdoom
1000 Posts Club!
- Apr 25, 2021
anyone got links for 5mm spacers that fit the front wheels? Thanks
15mm should work fine, and is readily available.10 mm won’t work because the lug bolts are too short to safely engage. i tried. You either have to go down to 5mm or up to 15mm bolt ons.
at least in the rear, hub removal is painful enough that I don’t think it’s worth doing the job.
Thats why I want 5mm. I know there are people on here who run them, and I asked them about them, but they might not be on here any more as the post was several years old.10 mm won’t work because the lug bolts are too short to safely engage. i tried. You either have to go down to 5mm or up to 15mm bolt ons.
well because 3-5mm spacers cant be hub centric just find any that fit the hub bore and bolt patternThats why I want 5mm. I know there are people on here who run them, and I asked them about them, but they might not be on here any more as the post was several years old.
sounds like a plan!well because 3-5mm spacers cant be hub centric just find any that fit the hub bore and bolt pattern
