Want to install some Konig Overstear wheels 19/8.5 30 mm offset with 225/40/19 front & 255/35/19 rear I'm trying to read facts all night anybody see any issues with offset on this?
Thanks guys.
Remember offset changes if wheel width changes. Only a 16.6mm difference in the back, considering a lot of people put 20mm spacers to make the stock rears flush it should be near perfect rear fitment. Front will only be 10mm further out should be fine too.OEM offset is 34 front 46.5 rear. That's quite a difference.
Thanks for responding I am lowered on springs not sure if that'll make any difference?It should fit fine but why use the same size wheels front and rear if you're using different sized tires? Might as well run a square setup and just go all 4 255/35 then you could at least rotate the tires.
should be fine either way.Thanks for responding I am lowered on springs not sure if that'll make any difference?
Thanksshould be fine either way.
