3.3TT JB4 # EWG Log review
Tim Rabb
Hi All,
This is my first post. I've lurked for quite a while and learned what I could from the resident experts. All was fine with my 2019 Stinger GT for almost 3 years. Then yesterday I installed the EWG wires and things changed.
I went for a blast to feel the difference. The car was pulling hard, about to auto shift 2nd, suddenly the motor began to surge. Like it hit a rev limiter. But it didn't. Max RPM was 6100. I let off it quickly.
So I decided it best to log a run this evening and see what the experts say. I believe I felt surging again, but it was very mild.
Thanks for your help in advance.
2019 Stinger GT
JB4 + EWG + Fuel wires.
Map 2
AEM Intakes
93 Octane
Did you adjust the setting in the app so your JB4 knows you added the EWG’s?.
Hi,
Yes. I followed N54tech guide. Also, my plugs are almost 3 yrs old (Denso .22 gap). I'm wondering if that could contribute.
Hi,
For the price of plugs I would swap them out for new. Fresh gapped plugs can’t hurt.
Logging seems to have stopped there also. Try to grab a couple more runs/logs.
It has been a while since my last post simply due to the weather. I had the mufflers deleted in the meantime which I like quite a bit. So today, with the new exhaust tone keeping me high, I went out early to log some runs. While on my way a new blacked-out BMW 540i pulled up next to me at a light. Nice looking car. Out of the hole we paced each other for a moment or two, then we hit it. I was pulling away quite nicely all the way up to 90 mph when I let off it. After just pushing the car full throttle through at least 2 gears, never once did I experience the surging issue that prompted me to start this thread.
I continued on to the spot I intended to log some runs. With my brake boost switch on, traction and stability control off, I suddenly accelerated at about 70% throttle as I merged with traffic. For the first time all 4 wheels spun from a roll as the car shot forward with impressive thrust. Then... the dreaded limp mode shut me down.
After that I was too concerned about the well being of the car to push it any more. Thus I did not log any runs. While it appears my original issue may be a non issue now, I'm curious as to why limp mode has entered the picture. Especially when the EWG wires should prevent it.
Perhaps your hpfp is crashing causing limp. There’s a thread or two on that issue which kinda sounds similar. Look forward to hearing more comments.
Oh, and set your JB4 to log at 75% throttle that way you would at least have a log from when it happened.
