StingerSteve02
- Oct 30, 2019
I was driving in forest/canyon roads coasting downhill, when the engine suddenly did not respond to throttle inputs and stalled, I shifted to neutral, and it started on 2nd attempt while coasting downhill.
After that, engine seemed to be in a "limp mode" with power limited and revs not climbing past 3500.
Same event happened 2nd time, did not start while rolling, brought car to a stop, attempted starting, struggled for about 3 seconds then fired up. Power seemed normal after that.
I've already had it towed to a dealership for it stalling before and they had to swap out a fuel injector, said it could be the fuel I'm using being old or not circulated enough at the gas station.
Does anyone know what issue this is and if they have experienced something similar?
