Bohemianangel
- Sep 30, 2022
Wipe everything down. And check that area in couple hundred miles. If it's wet, that woud indicate main seal. Hopefully you are still under warranty. View attachment 85179
I’ve got map2 jb4, intakes catch cans and plugs just hit 50k miles. Doubt they would do anythingWipe everything down. And check that area in couple hundred miles. If it's wet, that woud indicate main seal. Hopefully you are still under warranty. View attachment 85179
Jb4 will definitely void the warranty. And if the dealer knows about your tune, it is too late to remove it. Replacing main seal is a major job. Requires dropping the engine. Like I sad, clean it and check in couple hundred miles.I’ve got map2 jb4, intakes catch cans and plugs just hit 50k miles. Doubt they would do anything
Thank you for the help. I will try it. Fingers crossed lolJb4 will definitely void the warranty. And if the dealer knows about your tune, it is too late to remove it. Replacing main seal is a major job. Requires dropping the engine. Like I sad, clean it and check in couple hundred miles.
