20x9 aftermarket wheels
JDOGG
I have 20x9 wheels with 33 offset..I was jus wondering if I could fit 235 40r 20 tires on my 2022 Stinger..I had 225 35r 20 tires and they seemed a little too small of a sidewall for the roads around the tri-state area..
Welcome. Moving this to the Stinger wheels section.
Howdy and welcome: you can go up to a 265 width without any questions: 235 is the minimum width or else the tire will get stretched probably too much. The aspect ratio will only be an issue if your OD gets too big.
Is that square? As in all 4 are the same size? Should be fine for the rear..I think. Front may run into rubbing. I think the most common size I see when people go 20x9 up front is 245/35/20. Mine is +38 and the fronts have yet to rub once with my car lowered. It will also give you more sidewall than the 225/35 will.
Shouldn't be a problem. The only issue you may run into is if you decide to lower the car.
