1st Log Check
1st time pulling a log. Can anyone take a look and make sure I'm good.
'19 GT1 ,K&N Intakes, Big Mouth inlets, Denso IKH24 gapped to .22, muffler delete, 93 octane, Map 2.
2nd gear pull WOT.
Unplug the negative battery cable for a few min and grab another map2 log with adaptions reset.
Terry,
I actually posted a new log on N54. I reset it and am now running e30 as well still map 2 if you could check this log. Appreciate it.
Looks good now. See what Terry says, but if you have a good e30 mix going, I would try map 3.
Thank you! Actually ran a lot smoother after the reset and running e30 for the first time. Definitely wanting to try map 3.
I concur. Looks much better, I think you can confidently try map3.
Terry,
Seems good now with the better fuel! :)
Same thing happened on my first logs this weekend. Looked like shit until I disconnected the battery. Added a little e80 and logs are great now
