1st log check . Map1
Older firmware showed raw timing by default, newer firmware timing corrections by default.
knew it was the older firmware showing the raw timing. With good 91 octane you should be able to run map 1. anything 2.3 and less is fine. 0-.8 is great. I'm guessing you will likely just daily map 1 unless you can get the octane up to 93. Also, like someone above said, do a log from 20-100 mph, WOT. if you are 2.3 or below for timing deviation you should be more than safe.
