7thSonEngineering
- Oct 26, 2024
Goal: My goal is to replace the factory intercooler with an 1200hp rated air to water intercooler that has more capacity for cooling than any intercooler on the market for the 3.3t engines. I have already completed an air to water intercooler build on my previous car which was a built automatic genesis coupe 2.0t. This build was successful and I have been running the intercooler for 2 years at this point.
Reason: Superior intercooler efficiency, better throttle response, shorter intercooler piping, less lag, turbos don't have to work as hard to create the same amount of boost and the turbos will hold boost higher into the rpm range.
Steps:
1. Mock up the 1200hp intercooler to make sure it fits in the location I have chosen.
2. Order the 1200hp rated intercooler and heat exchanger, electronics and hoses.
3. Dismantle the factory intercooler and piping system.
4. fabricate an intercooler mount.
5. Design and construct the pump speed controller
6. Install and test
I expect this build will take me 1.5 months since I have already completed something like this before.
Steps:
6. Install and test
