Additional information
| Weight | 20 oz |
| Dimensions | 5 × 5 × 5 in |
| Oil Catch Cans | Dual Oil Catch Cans, Single Oil Catch Can |
Price range: $239.95 through $439.95
Single Baffled Oil Catch Tank for the 2018+ Stinger 2.0T. Installs on the passenger side onto two bolts that are already sticking out of the wheelhouse. Brackets that are Stinger specific are included for plug and play installation. Oil catch tank is designed and manufactured in Korea using 100% machined billet aluminum, with a cap on top to allow you to check how full it is. The interior is baffled, with a high quality 3M filter element to trap any particles.
Dual Baffled Oil Catch Tanks for the 2018+ Stinger 3.3TT. You can get the single can setup by using a Y-shaped fitting that will be included, or you can get the dual can setup that will be individually connected to each of the two engine heads. Please choose the type you want from the dropdown menu. Installs on the passenger side onto two bolts that are already sticking out of the wheelhouse. Brackets that are Stinger specific are included for plug and play installation.
These oil catch tanks are designed and manufactured in Korea using 100% machined billet aluminum with a cap on top to allow you to check fluid levels. The interior is baffled with a high quality 3M filter element to trap any particles.
| Weight | 20 oz |
