Additional information
| Weight | 0.20 oz |
| Dimensions | .5 × .5 × .5 in |
$4.95
You’ve rebadged the rest of your Stinger. If you want to cover that cheap looking KIA logo on your steering wheel, here’s one amazing new solution to your problem! This Kia Stinger steering wheel badge has a classy, but OEM style look, as it uses Kia’s own “GTS” text design in Federation Orange. Same day shipping makes this purchase a no brainer for anyone who wants what they buy right away. The wheel center cap overlays are available HERE.
It probably goes without saying, but the OVAL steering wheel overlay only fits over the OVAL KIA center-piece. If you have the newer style logo, this piece will not fit.
How difficult is this to install? Not difficult at all! They use high-tech specialty vinyl which allows you to position them, lift them back up if you need to, and reposition them over and over until you apply firm pressure for final installation. When you want to remove it, simply heat it up with a hair dryer for a clean removal – or use bug and tar remover to clean whatever adhesive may be left behind.
Our domed overlays are made from polyurethane resin and high quality vinyl. They’re resistant to water, salt, solvents, mineral oils and greases, ultraviolet (UV) light, and temperatures up to 170 degrees Fahrenheit (30 degrees Celsius).
| Weight | 0.20 oz |
