Plug ‘n Play LED Lit Devil’s Claw Fog Light Bumper Canards (set of 2 pcs)
$229.95
Fits the 2018-2023 Stinger GT models and 2020-2023 GT-Line models.
Upgrade your Kia Stinger with a set (2 pieces in each set) of these new LED Lit Devil’s Claw Fog Lamp Canards by Convoy. These “claw” shaped pieces are the perfect way to give an even more aggressive look to the front of your Stinger. They’re made of high-quality polyurethane material with white LED light. Same day shipping make them a no-brainer for anyone who wants what they buy right away.
Are these canards easy to attach to my Stinger? Sure are! Scroll down for an installation video. They install using the same high quality, automotive-grade double sided tape used on all exterior emblems.
Are they well built? Yes! The clear covering over the LEDs is made of acrylic – well known for transparency, resistance to breakage, and elasticity. These pieces have been tested in various harsh environments, including hot and freezing temperatures and kept under water for over a week. The manufacturer offers a three-month warranty on this product.
Note: Please make sure your front bumper design appears the same as in our pictures. These pieces do not fit the NON-GT 2018 Stinger…
With the older sets, you could only use the LEDs as the parking/DRL –  OR the turn signal. With these new sets, you can now use both functions. If you don’t want to use them as turn signals, then just unplug the yellow wire and it’ll keep the parking/DRL functionality only. So the yellow wire is used if you want to add the turn signal function. The blue wire is used if the daytime running lights don’t work with the red wire. In that case, just unplug it and plug into the blue wire.
The video below shows how easy the plug ‘n play version is to install:
Out of stock
SKU: PNP-LED-LIT-devils-claw-front-canards Categories: , Tags: , ,
Description
I first noticed a similar design years ago with the Porsche Cayenne – and I’ve always liked the look. These LED-lit devil’s claw foglight canards are the perfect, quick and easy way to set your Stinger apart from the inevitable crowd that’ll be on the road in the not-too-distant future…
Devil's Claw Fog Light Canards
Additional information
Weight 16 oz
Dimensions 10 × 10 × 4 in
Type
Black Carbon Plug 'n Play, Regular Black Carbon, Regular Matte
