Additional information
Weight | 0.20 oz |
Dimensions | .5 × .5 × .1 in |
$9.95
The E drive mode dial decal isn’t just a cheap graphic surrounded by a transparent layer of film. It’s an actual transfer – so there won’t be any clear bubbles surrounding the graphic. (GT version found HERE.)
It’s small – but easy to install: Prepare the surface (clean it), peel the backing away, then stick the decal to the surface. Rub the decal with pressure to ensure its sticking well to the surface – and slowly remove the top layer which leaves the decal in place – nothing else. So it’s ONLY the graphic that sticks to the surface. The images are not doctor’d. Installed properly, the decals will look exactly the same way they do in the photos.
Weight | 0.20 oz |
