Additional information
| Weight | 2 oz |
| Dimensions | 6 × 3 × 1 in |
| JB4 Fuel Wire Adapters | For 2.0T, For 3.3TT |
Price range: $35.95 through $69.95
This plug and play quick install adapter allows you to install a posi-tap for fuel control tuning without piercing the factory O2 sensor wiring providing a completely reversible connection. For 3.3 twin turbo models the signal wire is red for easy identification. For 4 cylinder models the signal wire is the black wire on position #2. The signal wire is red for easy identification.
Applications
• Kia Stinger, Genesis G70, and many other Kit/Hyundai Models
Notes
6 cylinder models require two adapters (select 3.3TT from the selection menu).
4 cylinder models require a single adapter (select 2.0T from the selection menu).
Notes
– 3.3TT models require two adapters.
– 2.0T models require a single adapter.
– The signal wire is red for easy identification.
| Weight | 2 oz |
