Additional information
| Weight | 0.60 oz |
| Dimensions | .5 × .5 × 0.5 in |
$14.95
YES! This is a complete set of FOUR center cap overlays! You do NOT need to add FOUR to your shopping cart!
Upgrade your Stinger with four of these OEM style GTS wheel center cap overlays in Federation Orange. (The surrounding grey piece around the overlay in the center is a separate item.) Same day shipping make our GTS overlays a no brainer for anyone who wants what they buy right away. These pieces fit ALL KIA wheel center caps. The steering wheel version is available HERE.
How difficult are these to install? Not difficult at all! They use high-tech specialty vinyl which allows you to position them, lift them back up if you need to, and reposition them over and over until you apply firm pressure for final installation. When you want to remove them, simply heat them up with a hair dryer for a clean removal – or use bug and tar remover to clean whatever adhesive may be left behind. These products will effectively cover up your KIA emblems.
Our domed overlays are made from polyurethane resin and high quality vinyl. They’re resistant to water, salt, solvents, mineral oils and greases, ultraviolet (UV) light, and temperatures up to 170 degrees Fahrenheit (30 degrees Celsius).
In stock
| Weight | 0.60 oz |
