Working on another project and will not be able to ship promptly until Saturday, November 1st, 2025.
GT Drive Mode Dial Transfer
$9.95
Convert your drive mode dial to a GT drive mode dial in red or white! The GT drive mode dial decal isn’t just a cheap graphic surrounded by a transparent layer of film. It’s an actual transfer – so there won’t be any clear bubbles surrounding the graphic. (“E” version found HERE). YES, you’ll receive EXACTLY what you see in the pictures!
It’s small – but easy to install: Prepare the surface (clean it), peel the backing away, then stick the decal to the surface. Rub the decal with pressure to ensure its sticking well to the surface – and slowly remove the top layer which leaves the decal in place – nothing else. So it’s ONLY the graphic that sticks to the surface…
SKU: gt-drive-mode-dial-decal Category: Tags: , ,
Additional information
Weight 0.20 oz
Dimensions .5 × .5 × .1 in
GT Drive Mode Dial Decal
Red, White
