Is it ok and will it cause any damage to drive in Sport Mode all the time?
I can live with that!
Leave your knob alone.......Sport Mode is an addiction, I did my best to work it off and use Smart Mode but, I just relapse and turn that knob to the right on start up.
Didn't I read somewhere that sport mode does not use 8th gear?No ill effects whatsoever. It's purely a choice. I drove from Utah to Texas and back completely in Sport mode. I got pretty good gas mileage too, either side of 25 mpg; and my highest was 28.6 (that was trending downhill out of the Rockies, with a tailwind).
Yep, 8th gear is not used in Sport mode & rev range changes up in most gears.Didn't I read somewhere that sport mode does not use 8th gear?
Thanks, would not want to cruise in 7th gear on interstate. I like the new trans when I can cruise at or below 2k rpms.Yep, 8th gear is not used in Sport mode & rev range changes up in most gears.
but i like to play with my button!!! muahahahahahahahaha.Leave your knob alone.......![]()
That was probably a silly non question. I drove with the paddle shifters and most of the time in 8th gear. It was good enough for most of the driving. When passing or getting out of the way (clearing the area) most of the time 7th gear was low enough to get the power I needed, and 6th gear was definitely low enough to meet all freeway speed requirements for acceleration. The first time I moved to the paddle shifters in Sport mode it was already in 8th gear.I never used 8th gear in Sport and with paddle shifters engaged (I discovered the manual gate afterward, heh). That's because I was consciously keeping my RPMs between 2K and 3K. Had I manually selected 8th gear, I wonder if continuing would have disengaged 8th electronically, or changed my "mode" to Comfort? Or would Sport have denied 8th gear altogether? Interesting question. I'll try it tomorrow.
nevermind.but i like to play with my button!!! muahahahahahahahaha.
You mean the 3.3L I presume. You weren't getting this car to get great gas mileage, were you? Because if you were, you're just going to have to live with disappointment. But if you drive it in Eco and strive for economy in that mode, you can get rather impressive results. Some on here have pushed above 30 mpg. I have managed 29 point somethingorother a couple of times.btw the gas mileage suks in the stinger....
My cummute 1s all of 2 miles, I'm lucky if the motor warms up by the time I hit either driveway.......wanna take the long way....but I may never get there! ( I'd just keep driving the stinger.........I have the same problem on my bike!lolYou mean the 3.3L I presume. You weren't getting this car to get great gas mileage, were you? Because if you were, you're just going to have to live with disappointment. But if you drive it in Eco and strive for economy in that mode, you can get rather impressive results. Some on here have pushed above 30 mpg. I have managed 29 point somethingorother a couple of times.
I would never drive my car if my work was that close. And even if I did, I'd let it warm up before shutting it down. Short hops, frequent starts and stops on a cold engine, are hell to pay later in wear and tear.My cummute 1s all of 2 miles, I'm lucky if the motor warms up by the time I hit either driveway.......wanna take the long way....but I may never get there! ( I'd just keep driving the stinger.........I have the same problem on my bike!lol
