I have them. Remember, after drought years in California (which I think have returned already), there are massive mudslides the first time there's a drop of rain, and our infrastructure is so ancient and rotten that pipes are always breaking and flooding the street somewhere!I wonder if there would be enough demand to warant the effort ? They are a pretty logical accessory for all of us living where we get rain,snow etc but in drier climates I doubt many owners would want them ???
So just finished the install of the mud guards , its something anyone can do if you're handy and have the proper tools if not let your dealer do it , The fronts are easier because you can turn the wheels for more room , the rears are really tight especially if you have large hands like me . You need an offset screw driver $7 and an auto clip removal tool $8, pics below . The finished look is virtually unnoticable and the black seems to complement the other black trim on the vents etc so I think it looks fine and I'm very happy to have the reduced road debris and crap that can muck up the lower sides of the car. CLICK the thumbnail for more detail.
Cheers
Is it bad if this hurts my eyes?They look good! How do they perform? Do you find your car's lower sides are not as dirty? Can you post a pic?
For comparison, here's how mine looks like just after a few KMs on our wet salty roads.View attachment 2140
They make a difference , I think your solution is to move to Florida though !!They look good! How do they perform? Do you find your car's lower sides are not as dirty? Can you post a pic?
Installed them this evening. Not exactly a cake walk. I still can't get a clip on the bottom of the front guards. I'll need to put it on a lift to get them in. Not really necessary though, they are secure with a screw and one clip.
I needed 2 new clips when I did mine last year .Same like you, I could not put in on one of the fastener clips in the same location as you. Simply, the inner expansive tip don't run all its way. I left the mud guard installed with one clip and the screw.
I thought that I need more grip exercises with my "lady" hands.....or some of the layers to be coupled are not aligned properly .....
I´ll go to the auto parts shop to purchase a couple of these with the original diameter of the OEM clip
View attachment 6886 View attachment 6887
Nice job, I like the vent mesh screen install, very clever, is anyone marketing/selling these?I installed my splash guards yesterday. It took about 20 minutes to install...5 minutes each. Very simple to do. I saw someone put a screen on the brake vent in the wheel well (another post on this site). The person that posted said rocks went through and chipped the rear door paint. So, Menards had this black screen in near the grill accessories for $3. The screen is anchored by the two black pins. The screen extends about 1/4" all the way around except for the parts that extend to the plastic pins. They took about 20 minutes to install.
Looks good in there, and I like that it will still pass a lot of heat/air vs. the perforated panels I saw in the other post. Is the material plastic or metal - what was the 'intended' application for that screen?So, Menards had this black screen in near the grill accessories for $3
kidney stones ....... no seriously !Looks good in there, and I like that it will still pass a lot of heat/air vs. the perforated panels I saw in the other post. Is the material plastic or metal - what was the 'intended' application for that screen?
Did the mesh sit in the vent hole or over it? Because if it’s over it the lining won’t seal the water out from getting in behind the lining and causing rust. My ones sit in hole don’t need fixing as the lining holds it in place.I installed my splash guards yesterday. It took about 20 minutes to install...5 minutes each. Very simple to do. I saw someone put a screen on the brake vent in the wheel well (another post on this site). The person that posted said rocks went through and chipped the rear door paint. So, Menards had this black screen in near the grill accessories for $3. The screen is anchored by the two black pins. The screen extends about 1/4" all the way around except for the parts that extend to the plastic pins. They took about 20 minutes to install.
Use stainless steel mesh, no rust issue then.Did the mesh sit in the vent hole or over it? Because if it’s over it the lining won’t seal the water out from getting in behind the lining and causing rust. My ones sit in hole don’t need fixing as the lining holds it in place.
View attachment 8271 View attachment 8272
Behind the lining, the water will sit in the fender door area not the mesh.Use stainless steel mesh, no rust issue then.
Oh gotcha.Behind the lining, the water will sit in the fender door area not the mesh.
So since you have had the mud guards on for a while now, would you say they have been worth it in regards to keeping muck off the car? They seem pretty small compared to other mud guards and I was curious to hear if they still did a decent job.So just finished the install of the mud guards , its something anyone can do if you're handy and have the proper tools if not let your dealer do it , The fronts are easier because you can turn the wheels for more room , the rears are really tight especially if you have large hands like me . You need an offset screw driver $7 and an auto clip removal tool $8, pics below . The finished look is virtually unnoticable and the black seems to complement the other black trim on the vents etc so I think it looks fine and I'm very happy to have the reduced road debris and crap that can muck up the lower sides of the car. CLICK the thumbnail for more detail.
Cheers
