[VENDOR][FS]: Kia Stinger Storm Lowering Springs - K8 Stinger Store
Daniel @ K8 Stinger Store
Authorized Vendor
Is proud to present to the Stinger community:
(BUY NOW)
Description:
Built specifically to improve your Kia Stinger's handling characteristics with track-proven results
Manufactured in S. Korea from 100% cold-forming steel
20% stronger and lighter than factory spring
Better performing progressive spring rates
Features and Specifications:
Drop Height: Front = 0.8"/Rear = 0.6"
Includes (1) set of 4 lowering springs
Stop quicker and corner faster
Lower center of gravity
Vehicle Application:
THANK YOU FOR LOOKING!
awd drop is 0.8 and 0.6?
If awd is .8/.6 what is the range for rwd? Awd is about .5 inches higher than rwd, so rwd would only be .3/.1? That doesn’t sound right.
I'll try to figure this out, just going off manufacturer specs and they do not list if its AWD or RWD
On the flip side, if the .8/.6 are the drops for the RWD cars, then that would make it more like 1.2ish/1.0ish drop for the AWD version, which would make more sense.
Are you looking for authentic KDM Lowering Springs?
Storm Lowering springs are manufactured in South Korea and have an OEM-like quality!
These springs will instantly give you the confidence and road appeal you have been searching for.
The modest ride height drop from the enhanced cold-forming steel is the perfect option for every daily driver.
(CLICK THE IMAGE BELOW TO PURCHASE OR FIND MORE INFORMATION)
