Stanger21
Having searched the forum it seems like a fairly common issue that people have a pumped brake pedal after leaving the car to sit for a day or so, I've had it happen very sporadically myself. It can happen 3 days in a row then not happen again for another 6 months so it seems there's no rhyme or reason to what sets it off. It's never actually caused me an issue but it does point to something being not 100% right so I'd like to address it if its an easy project (I would expect nothing but excuses from my local dealership so I'm not even going to entertain having them take a look)
The check valve seems to get mentioned as a likely culprit quite a bit so I'm thinking if it's an easy swap then it's a good place to start. My question is, can anyone confirm that the brake booster check valve is the part marked in the pics below? And does anyone have an experience of replacing it as a valid fix for the issue?
