Transmission leak
CheldonAc
Gresham OR
Transmission question/concern: I have a 2021 Stinger GT2 AWD w/ 25,000 miles. While doing an oil change last week, I noticed a few drops of transmission fluid at the bottom of the transmission closest to the oil pan. No leaks from the top and no fluid on the skid plate. Shifts are still perfect while driving (I only drive aggressively on occasion). Has anyone experienced any minor trans. leaks before? I've had a Lap3 TCU Stage 2 for the past year and haven't had any issues until now. Any ideas would be appreciated. Thanks in advance
I know that anyone else will say, "Clean it off and keep looking to see if or when the drops return." You don't know how long it took to accumulate that little bit. If it's just starting you'll know pretty soon by observation. Conversely, if it stays clean for a long time then you don't have an issue.
Sounds good. I'll look at it this weekend and give an update.
oil leaks always look worse than they are
I had a slight diff leak on a truck for about a half decade before I finally pulled the bed to get to it.
Diff was about 1 tenth of a quart low
