That would be a good Stinger owner public service announcement, to check for correct installation.your front undercarriage panel is ripped; probably happened going through that 'puddle.' but it fell because the front clips failed, and they probably failed because Ima guessing the panel was put on improperly, it's supposed to be above the bumper cover, not clipped to the bottom of it.
That’s my question too. I know they help, but how much?I've gone through two of them with dealer replacement at $500 and then $570. How important are they?
They keep out all the road grime dust and weather out of the engine bay at a minimum. I’m shocked how little I’ve had to clean my engine bay. Just easy wipe downs with quick detailer and no signs of road salt.That’s my question too. I know they help, but how much?
share details, why you are on your third undercarriage panel. how did it happen?I've gone through two of them with dealer replacement at $500 and then $570. How important are they?
2018 is not special in this regard. Same ride height across all years.The2018Stinger rides low to the ground. I live in Houston which has lots of objects on highways that you don't/can't always see. I've been through 3 deflectors now. Wondering if I should simply leave the engine exposed and have the underside cleaned every now and then. Most Kia parts places online have the same grift: huge discount, then once you enter all your info to get to the final payment, they have outrageous shipping (and taxation) fees.
Good luck with that one. The OEM undercarriage panels are as cheap as they come. They just cost a lot. Hah. They are sturdy enough as long as they don't come loose. That's not the panel's fault. It's the clips. Just make sure that they are snapped solidly into place. It's really easy to mistake them being all the way in when the center hasn't actually penetrated fully into the outer piece. To assure full connection, remove the center piece, push the outer piece all the way in, then push the center piece until it is flush. You'll also feel/hear it click.Hopefully I’ll find a cheaper aftermarket
On the stinger, isn't there only 1 single plastic push rivet to remove during an oil change? (The one the give access to the oil filter)When that undercarriage panel fails, it is most often because some of the clips were missing or not installed properly, or the panel was previously damaged from hitting something. Otherwise, there is little reason why it would all-of-a-sudden just go flying loose.
This is yet another reason I do my own wrenching. Good opportunity to inspect at every oil change, since that panel has to come off. Between our 3 Stingers/G70, I've already had to change out probably close to 10 clips. Sometimes the clips break off a leg, sometimes the holes the clips go in get a little overworked like a veteran at a bordello and fit a little, uh... loose. Best thing to do is to get one of those multi-pack body panel plastic clips with a wide assortment of styles and sizes. That way, you can change out on-the-spot any that are missing or questionable.
Plus, there is only ONE right way that panel goes back on. If you are not careful, you could insert one or more of the attachment tabs the wrong way.
The grease monkeys at Jiffy Lube or the dealer service aren't always gonna take the time to put it back properly. Just about every single vehicle these days have an under tray. These guys get paid by the hour and they see 50 different cars a day. They don't always pay attention when reinstalling those trays. As long as nothing happens when you roll off the lot, they couldn't care less.
